Results 1 to 10 of 13
Thread: head gaskets
    Jan 2011
    az
    head gaskets
    Hey guys, I was wondering what head gaskets should I use?? My bore is 91.87mm. For the last 2 motor builds I've used 95mm mls cometic gaskets. I also have the full arp stud kit. should I get rid of the arp head bolts and run oem .my plans are to make great power.
    Medford OR
    You will get varying opinions I'm sure... My opinion on the ARP studs is they are not worth buying, but I'm not convinced they're worse than the stock bolts, or worth getting rid of in favor of the stock bolts.
    I would use O.E. or Fel-Pro gaskets... (I'm not convinced Fel-Pro isn't supplying the stock gaskets... You'd have a hard time telling them apart.)
  3. The Following User Says Thank You to RealMcCoy For This Useful Post:
  4. #3
    Never finishes any verified
    Wake Forest, NC
    Agreed!! Felpro HG & OEM head bolts.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  5. The Following User Says Thank You to DrGonzo For This Useful Post:
  6. #4
    Why are people STILL buying cometic head gaskets? There's like a decade worth of data confirming that they suck.
    New OEM gaskets and new OEM bolts. Anything else is just begging for trouble.
  7. #5
    SKADOOSH!!! verified
    Prince George
    OEM head bolt, FelPro head gaskets. ARP main studs, and rod bolts. If you're going for some big power, have a machine shop do copper o-rings on your block. You'll never leak.
    Photobucket
  8. #6
    Jan 2011
    az
    Thanks for the help guys . I made some mistakes on the parts I've baught in the past. I just bent valves again so I'm looking to buy the best of the best this time. So you guys say ditch the arp head bolts and run oem and oem headgaskets?? The 92mm stock bore headgaskets should work with a 91.87 bore or .030 over ?
  9. #7
    Prince George
    Quote Originally Posted by keo92stealth View Post
    They will work, stock head gaskets are a 92.0mm bore size. Anything larger than a .040" bore requires an up-sized HG.
  10. #8
    Jan 2011
    az
    Quote Originally Posted by J_Parker View Post
    Sounds good. Looks like ill be looking for some stock head bolts and gaskets instead . Thanks for the help guys
  11. #9
    Jan 2011
    az
    Honestly I don't think the big hp guys like ray do the o ring . He just does the head lift fix thing .
  12. #10
    Prince George
    It's not a critical thing to do, Chris Hill, and a few other big HP guys have done it (I myself will be getting my block done as well).
    Doing Ray's head lift fix and O-Ringing will ensure a bullet proof deck surface on either side of the HG.
