Got my injectors (used tt) can anyone suggest the resistors I should used and any tips on wiring them up?
I believe I used 6.5 ohm resistors from partsexpress.com when I did my conversion and wired them into a patch harness I made myself. You can just cut into the harness near the ecu though and put them there. I think it was like 13 bucks or something for all of them. I'm 90% positive about 6.5 ohm.. but it was a few years ago that I did that.. Good luck
Got them from Mouser.com about $6
Seeings how I'm getting more adapt at inserting pixs, below are a few photos of how I wired in the resistors. The resistor pack was made using ABS plumbing fittings and was used to service the 3 rear injectors. The front resistors were spliced and soldered and hid in the flat plastic wire conduit that sits above the front injectors.
The main reason why I wired as I did is I wanted to ensure that I could access any resistor simply and without pulling the intake manifold. I also wanted the install to be clean and look professional ie., no resistors wrapped in electrical tape and laying on top and under the manifold. BTW, I painted the resistor b4 I installed, just roughed the ABS to ensure the wrinkle paint stuck.
[QUOTE=ibsorgn;193885]Seeings how I'm getting more adapt at inserting pixs, below are a few photos of how I wired in the resistors. The resistor pack was made using ABS plumbing fittings and was used to service the 3 rear injectors. The front resistors were spliced and soldered and hid in the flat plastic wire conduit that sits above the front injectors.
Tried to think of a better way but nothing came to mind. Followed along your ideas and it came out very neat and clean. Appreciate the pixs.
