Results 1 to 3 of 3
Thread: Need help quick
    2004/5?
    SW Connecticut
    Need help quick
    Hey guys, I was trying to change the rear motor mount, had problems removing rear o2 housing and gave up. Buttoned it up again, changed th e oil and started it. Now it's idling around 2k and oil pressure gauge isn't moving at all (bottomed out). What did I screw up?
    Sent from my Motorola Atrix
    CowTown
    Oil pressure sensor wire probably came unplugged. high idle may be a coincidence or vacuum leak.
    2004/5?
    SW Connecticut
    Yep the sensor just got knocked off. Idle was caused br acc cable tension over my dnp pipe.
    I'm now trying to attack the whole turbo removal so I can drill out the studs. will I be able to lift the o2 sensor housing out with the turbo easily? I think I read that removing the ps line was a necessity?
    I'm headed to autozone now for supplies including new studs and nuts, pb blaster/aerokill, line wren,hes and cobalt/carbide tipped bits. Any other suggestions or tips? I took the day off of work so hopefully I can tackle all this.
