Results 1 to 2 of 2
Thread: Battery Relocation Kit
    Crimson Jihad Not Verified
    Looking to pick up a battery relocation kit that is known to work in a 3/S with no problem.
    CAUTION: Over Boosting May Cause Accidental Orgasm.
    1993 Mitsubishi 3000gt VR-4
    94 3500gt vr2? verified
    NC
    I just used a 0awg amp install kit, $40 on amazon. The rest (brackets, hold downs, box, etc) will be different depending on what type/size battery you are using.
    I recommend high count ofc cables.
    *Optional - I also picked up some distribution blocks for power and ground wires to make it a little easier for amps in the trunk and for the starter/fuse box wires under the hood.
    If you need help with grounding locations, I have some pics that may help.
