Page 7 of 19 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 186
Thread: My 6g74 tt build
  1. #61
    94 3500gt vr2? verified
    NC
    i may just go with the weld on fittings instead. The idea was for it to be either not require welding or be more secure with bolt and weld holding it
  2. #62
    I don't bite
    Southern IN
    oh and that threaded section looks like a restriction. look how much of the internal diameter is lost.
    QFT. You want as big of drain and fittings as possible. I used the aluminum bolt on -10AN fittings that bolt to stock TT pan. Also gasket matched them by drilling out the mounting side with a stepped drill bit in both the turbo and pan fittings.
  3. #63
    Apr 2011
    Mid-April 2011.
    Monroe WI
    subbed
  4. #64
    NC
    I changed my order to the weld on fittings. I'm not sure if the internal diameter was lost on the others or not. Hard to tell from the pics, but it doesn't matter now anyway. The weld-on's are also cheaper.
    Anyone have some precats or better yet, some precat deletes?
    Also, recommended oil cooler?
  5. #65
    NC
    oil cooler
    new tt oil housing
    Test Fitting *I think this is right...
    *Looks like my rear actuator needs to be replaced. I'm considering an upgrade kit with wrx diaphrams
    Coming along, mostly just need a front o2 housing and oil cooler lines. Should be starting this project first week of May
  6. #66
    nice! keep us posted.
  7. #67
    VR-3747 :D Not Verified
    Dayton Ohio
    man, i just dont know how you can justify putting 9b's on that engine. such a restriction. on a side note, im sure you will hit full boost by like 1200 rpm's haha
  8. #68
    NC
    That's the idea
    How's yours doing btw?
  9. #69
    NC
    My rear actuator looks damaged. What do you guys think of this kit? I'm thinking about option #3. Or would it be better to get some 13t's or something?
    3000GT/Stealth International Message Center
  10. #70
    JNS Engineering verified
    San Jose, CA
    I don't think he's selling option 3 at this point. Funny because he sells the WRX springs separately. I'm on the waiting list but I'm pulling out because I found a set already to ship.
