Page 3 of 19 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 186
Thread: My 6g74 tt build
    94 3500gt vr2? verified Feedback Score 9 (100%) n2nsanity's Avatar
    NC
    I believe it's the 3 connector. I swapped harness and ecu from the 5spd donor car, so obviously there wasn't an issue with the connectors. The only wiring issue was the clutch safety switch. I didn't realize until after the conversion that this was part of the interior body harness. Not a big deal as I plan to install a neutral safety switch later. This also affected cruise control. When using cruise control, if I press the clutch the engine rev's up, lol.
    I'll definitely have to look into the flashable vr4 ecu compatibility. I think someone makes adapters and I really don't want to swap harnesses again.
    NC
    Well, I think I'm ready to start on this. I want to do the oil returnts 1st. I already need to do my oil pan gasket anyway. I was thinking I could go ahead and put the return fittings in and cap them off.
    Would this kit work? Should I use 2? Or just use the junction?
    UNIVERSAL 36" TURBO/ TURBO CHARGER TURBOCHARGER OIL FEED LINE 1/8 FITTING T3 | eBay
    Can I use a 2nd kit for the feeds? What's the length of the feed and return lines?
    August 2010
    Chicago
    if you're in the market for a walbro 255 and stock TT fuel injectors I've got both. You can have them for $110 shipped..you can PM me for more info.
  4. #24
    NC
    Thanks. I believe I have a walbro 255 installed already. I think I have TT injectors also. I need to check the #s on them to see what they are.
  5. #25
    NC
    Well I've got a few parts now. Only $220 invested so far
    Jared found me a local guy who is parting out a 93 vr4. I should be getting everything but the ecu from him sometime this week
    In a month or 2 hopefully I'll be able to get one of the flashable ecu's and harness adapter. I'm hoping the adapters they sell will work for NA harnesses too. Worst case, I'll have to also buy a vr4 engine harness.
    With the flashable ecu and maft2, I'm not sure I'd need the safc2. Is this correct?
  6. #26
    Correct mate, Fully programmable! Ditch all the extra electronics....
    I'll just be running the 99 ECU and that's it. get it tuned once and once only.
  7. The Following User Says Thank You to TUFFTR For This Useful Post:
  8. #27
    VR-3747 :D Not Verified Feedback Score 1 (100%) futurevr4man's Avatar
    Dayton Ohio
    with the flashable you wont need the safc2 OR the maft. the ecu can do it all
  9. The Following User Says Thank You to futurevr4man For This Useful Post:
  10. #28
    NC
    the flashable ecu can handle the gm maf?
  11. #29
    Dayton Ohio
    oh whoops, no. it cant. i was thinkin you were going to use that maft to tune with still. you ought to sell that and get one of the cheap ones
  12. The Following User Says Thank You to futurevr4man For This Useful Post:
  13. #30
    why do people hate piggybacks so much?
