Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 116
Thread: top speed run 3000gt sl
    Again, retest this with a GPS.
    It doesn't hurt to double check and will back up your statement.
    Quote Originally Posted by Street_Chally73 View Post
    Cool story, bro!!
    And indeed, Cool story, bra
    Aug 2011
    Ok again, hope you're not doing this on public roads, man. Top-Speed runs on public roads are usually more dangerous than drag-racing. What if you blow a tire at 145?
    Also, here's why you shouldn't worry about anything that you brought up.
    1. Top speed is irrelevant. Acceleration is the fun bit. Kids always ask me how fast my car goes and what the 'speedometer goes to' as if it's a measurement of car-peen. Unless you're drag racing, the butt-dyno is all that matters. You drive it 'cause it feels fast until it doesn't feel fast anymore, then you mod it. Besides, how much time do you spend at top-speed compared to accelerating?
    2. Top speed is unreliable. Speedo's are off constantly, sometimes upwards of 10mph or more depending on tires/wheels/mods. Your car could be 'off' because somebody put slightly oversized tires on your car, or slightly undersized on your old car, for example, but those are one of a dozen reasons why this is wrong.
    3. There is nothing remotely scientific about these methods you're using man, you have to allow for some room for error and a 10% margin of error isn't outside the realm of possibility. Two different cars, two different days, two different body styles (I'll get to this in a minute) compounded with the aforementioned fluctuations in reported top-speed all leads me to say that even comparing these two cars in top speed is an exercise in futility.
    4. Just because something looks more aerodynamic doesn't make it so. If it's the case where you have some experience in aerodynamics then I retract this statement.
    I love hearing about people getting into these cars. It's like a club. We all have fun. We've all done some dumb things in our cars. These cars are, however, becoming more and more rare and I would hope that each one that people own for a better reason than "because it's pretty" is well taken care of.
    And finally, in the spirit of providing a solution rather than just pointing out flaws, if you're truly concerned about it, put the car on a real dyno to get the true HP number because often you can find that you're missing more or less than you'd expect and start the troubleshooting there.
    Also, you can use this: Gear Ratio Speed Calculator
    This will tell you your car's top speeds in each gear if you input the right info.
    Have fun and please stay safe, man.
    1991 Stealth ES (Sold)
    1994 Stealth RT/TT
    1995 3000GT (Sold)
    still hasn't provided the weight of the car he's comparing it to. if it's a 2000 lbs car with 170hp, then i'm certainly not surprised.
    weight of my old car was right at 3000 lbs I believe the 3000gt is sitting right around 3200 if I'm not mistaken so not to much of a difference. but I think it's irrelvent to compare at this point anyways as I have read on other forums and now even here in my own thread that my car should be doing 140+ mph as others have gotten theres to do, so obviusly something is wrong I just don't know what.
    I Kill Threads verified
    Wichita KS
    Use a speedometer app on your phone (they're free) that'll be more accurate than your speedo. And like others have said, if you have different sized wheels, in diameter, not width, that'll throw the speedometer off.
    Could also be that you aren't making the horsepower to get there. Also like said top speed is only a factor of horsepower, aerodynamics and gearing, so assuming your completely stock, aero and gearing would tell you that you can reach about 140, that just leaves horsepower as to whats limiting you.
    1992 3000GT VR-4
    YOUUSSS TRROOOLLLIN supporter
    Boston, MA
    Quote Originally Posted by sketch View Post
    Why are you trying to hit 140?
    Are you manual or automatic?
    The FWD manuals are geared to hit ~110 in 3rd gear alone.
    Edit: also, at 170k miles you should plan on doing a 60k service sometime soon (depending on how often you drive your car)
    You seem to have missed my questions. Bump
    -jeff
    1992 SVX LS-L
    1996 3000GT FWD-TT
    2005 XC90 T6 AWD
    i collect parts.
  8. #18
    Taichung, Taiwan
    I hit 145mph in my NA with 130,000 miles on it. There is something wrong with yours...
    1995 3000GT VR-4 Black
    K&N Air Filter / Topline Engineering Ground Kit / Precat Eliminators / Walbro 255 / DNP Downpipe / 3SX Fuel loop / JDM EVO MR BOV / Hallman Pro RX / 3SX Single Pass Radiator / Tein S-techs / 3SX Rear Control Arms / 3SX Custom Poly Motor Mounts /
    306.5hpawhp 320.5awtq @14psi
    Sold - 1994 Mitsubishi 3000GT Pearl White Base
  9. #19
    Stuper Moderator
    January 2003
    It's hard to tell what could be wrong. My first guess would be to check compression, if your plugs/wires/coils are in proper working order.
    Douches
  10. #20
    Advanced Tech? verified
    i'm also thinking compression is down if it doesn't act strange otherwise.
