View Poll Results: ATR or Tanabe Knock-off
Voters
12. You may not vote on this poll
  • ATR
    2 16.67%
  • Tanabe
    10 83.33%
Page 11 of 13 FirstFirst ... 910111213 LastLast
Results 101 to 110 of 128
Thread: New Car Pearl White 95 R/T TT
  1. #101
    Good habit to get into is pressure testing the fuel system before starting the car. You can do this with evoscan or by touching the black connector by the battery to the + terminal.
    No long cranking either after depressurization the system.
    that is a great idea really. I just get in a hurry sometimes when I want to see if something works you know.
  2. #102
    ah, got the silver car home today. It is super pissed. I think the injector insulators are leaking. Either that or the ecu I picked up off ebay is hosed. Feels like a good sized boost leak though.
    Spare trans I had shifts great though and no complaints from anything else.
  3. #103
    Sent from my DROIDX using Tapatalk 2
  4. #104
    it is an absolute joy to remove turbos that have never been off.. broke two bolts on the front turbo already. going to be fun drilling those out.
  5. #105
    One fix at a time verified
    Kansas
    I did the same thing on my front turbo. Busted two bolts but thankfully the rear stayed in tact. PB Blaster and heat didn't work on the front for me.
  6. #106
    STL, MO
    Got my front turbo off the car the other day... Only bolt that broke was one of the ones on top... But I got lucky and was able to twist it out...
    1991 Stealth RT/TT
  7. #107
    wow these bolts broke off in the turbine housing are the most seizeds thing I have ever seen and I have worked on antique ag equipment. I weld nuts on them and it just breaks off even with the nut. I heat them for several minutes with a map gas torch and then use freeze off on the studs. Then I grab a pipe wrench and put a pipe on the end of it and the whole stud turns like 1/16th of a turn and snaps off below the surface.
    off to turning my drill bits into shit.
  8. #108
    Delaware
    ....damn, id just find new turbine housings..lol
    Jason
  9. #109
    I lack color... verified
    Aug 1998
    Sounds about right....
  10. #110
    Jason
    yeah I'm tempted. Also tempted to find a pair of dr500s or something and sell these 9bs to matt as cores (if he'd want them)
