I've got this issue I haven't been able to diagnose...I don't know how you'd describe it, but it's like a rough engine that feels like a consistent fluctuation/cycling of vibration starting at around 2400rpms and doesn't go away until about 3100rpms. It goes away once past 3k rpms and doesn't do it on decel in that range, runs seemingly strong once in full boost (3100 to redline) There's also a hesitation when leaving from a stop, doesn't seem to do it all the time, I guess it's dependent on load/rpm combo and going from 2nd to 3rd depending on load/rpm combo it'll backfire sometimes too
I pressure checked everything and am good there, the only place I couldn't really check was lower intake plenum (for lack of visual capabilities), and it almost seems like it miiiight be a vac leak since idle isn't the best, and it happens in that rpm range worst when crusing, where you'd probably be seeing more vac than pos pressure, I don't have a gauge...
I did however, hook up a mighty vac that does pressure and vac and only measured 15-17hg of vacuum which from what I've come across it should be 20, so I don't know if that is a sign of a problem nor how accurate that gauge is
I took a few data logs awhile ago, they're in .xls format wasn't sure what to log so I don't know if I got everything I should've gotten and I don't know what I'm looking for, I could upload those if anyone's interested
I pressure tested up to 20psi but I had a hard time holding the pressure for longer than maybe 5 minutes, but sprayed the crap outta the entire system with super soapy water n fixed anything that showed signs of a leak, the only place I couldn't get anything into or get a visual on is the lower plenum
Thoughts? I'm tryin to think of anything else to add...I haven't had the time to get on here to ask for thoughts, I tested and did all of this about 3 weeks ago and am recollecting off the top of my head...
F.Y.I. Everything is stock running WG pressure, only mods that'd change performance are complete vac reduction, and gutted pre cats and cat back exhaust with gutted main cat
