-jeff
1992 SVX LS-L
1996 3000GT FWD-TT
2005 XC90 T6 AWD
i collect parts.
found one........it was still apart at this stage, so don't mind the mess
Necro bump!!!!
Hey Sketch, did you get anywhere with this? I'm looking to do the same. It doesn't look like there's enough room in the ebay y-pipe to put the maf in without using a 90* coupler.
The 3" maf is actually 3.25" (IIRC) and the TB is 2.75". I haven't found a 90* 3.25 to 2.75 silicon coupler in existence.
Use a 90* off the throttle body to the gm maf. Then cut the y pipe right after the bov tube and roll a bead on the end. This setup held 25 psi for me with no issues. I also had a meth nozzle in the 90* coupler.
That's what I was wanting to do but I can't seem to find a coupler for it. My maf is 3.222" and the throttle body is 2.75". Are you using a 3" to a 2.75 reducer elbow?
I could see a 3" stretching a quarter inch to fit the maf but I'd rather not shrink the other end a quarter inch to get it to fit on the TB.
Well I just ordered the ebay Y pipe and a 3"-2.75" 90* reducer coupler for 55 bucks. That's worth it to try it out.
