Results 11 to 20 of 25
Thread: Problem with my SL: Klunk in the passenger front.
    Never finishes any verified
    Wake Forest, NC
    Jack test first and see if there is anything loose when you move the wheel.
    Could also be something worn in the strut like the upper mounts or perch.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    Madison Heights, Mi
    safety inspection, whats that
    MY main consern right now if is something that will fail horribably if I drive it for a few days while its hotter than hell out. Sounds like worst case it will just make nioce and virbration as long as I don't drive like a nut.
    Stuper Moderator
    January 2003
    Best advice.
    Douches
    Wake Forest, NC
    It could be your A/C trying to come on.....LMAO!!
    might be a worn cv joint....
    Madison Heights, Mi
    AC works fine in the SL
  7. #17
    head's up though. if you do replace ball joints, tie-rods, strut mounts, etc....you'll want an alignment.
  8. #18
    Sep 2011
    Missouri/ north Dakota
    Alan when my bearing was bad it also would make the clunk on decell
  9. #19
    1994 3000GT Original Owner. verified
    August 1994
    Bel Air, MD
    My NA was making a terrible "clunk" when going straight but over a bump....like a speed bump or small uneven place in road. Also did it sometimes when just taking off. It was the end link.
  10. #20
    Sep 2011
    Did you ever figure out the clunk?
