Results 1 to 5 of 5
Thread: Piston Ring gaps
    Oct 2011
    Grande Prairie, Alberta, Canada
    Piston Ring gaps
    I'm gapping my Hastings (2C4670) rings and thought I'd ask here before I wreck this set. Ross pistons + 040. Got a tip from a performance guy locally who suggested I calculate gap using cyl bore x .0080 for the top ring and multiply that result by 1.5 for the second ring.
    So 92.0mm x 0.0080 = 0.736mm (0.029") for top ring and 1.10mm (0.044") for the second.
    I've seen reference to that to ring formula on one Hastings tech article but can't find anything on the second ring although I have seen other references indicating to add 0.0005 to the calc factor for the second ring (so 0.0085).
    Does anyone here have some solid help and guidance to offer?
    Des
    Sent from my Galaxy Tab 10.1
    Des
    Grande Prairie, AB
    Most of those gap calculates are the bore in inches times your ratio. Those gaps you gave are therefore quite excessive. Your 2nd ring gap is about twice too large.
    Sent from my DROIDX using Tapatalk 2
    Medford OR
    Edit: nevermind... I see what you did..
    That's way too wide though... I'd put the top ring in the low 20's and the second ring a couple thou bigger.
    Oct 2011
    Most of those gap calculates are the bore in inches times your ratio. Those gaps you gave are therefore quite excessive. Your 2nd ring gap is about twice too large...
    ...That's way too wide though... I'd put the top ring in the low 20's and the second ring a couple thou bigger.
    Thx very much, I appreciate the help and confirmation and really helps me a lot.
    Des
    | @/|/| +|2()|/| verified
    December 2009
    Fox Cities, WI
    About what I set mine to. Runs good. Still only ~500 miles on her though.
