Are you sure it's oil starvation? Most of my issues has seemed to be too much pressure on the turbo seals via crank case pressure.
Sins I really don't believe thats why you are blowing turbos. You are definitely over spinning them. With closed wastegates you said you were only making 18psi and you ran it like that for a while. Check for boost leaks and don't close your MBC.
Trash Can Club
Dave, im getting everything fixed I was told from dan from mtc that it looked like my rear was getting starved for oil. here are some pics of my front bearing housing too btw and some of the thrust bearings
and my bearing housing
holy shit, never seen a crack like that.
