Page 1 of 28 12311 ... LastLast
Results 1 to 10 of 285
Thread: K&N 1005 Larger Filter in stock location
    Thanks to a fellow on the other site and some internet cross referencing I have confirmed that the KN 1005 oil filter will fit in the stock location and screw right into the filter housing. It fits just fine on the sealing surface and the threads are the same.
    Compared to the stock size filter this thing is huge, the dimension listed do not reflect really how much bigger this filter is until you use both side by side.
    This thing BARELY fits. I would avoid non K&N styles for this filter size because you probably won't get a filter wrench on this, but the nut will work fine.
    This barely cleared my aftermarket oil cooler fittings, but nothing rubs and it fits like stock except its huge.
    It holds a full 8 oz of oil. I did not measure the stock size filter, but I would judge it to be 2 more oz than stock at least. Hopefully someone with a new clean filter can test it for me.
    I finally found a filter than looks like it isn't meant for a lawn mower.
    1.Fits like stock.
    2. Cheap, about $10 on sale.
    3. Locally available.
    4. No mess or having to clean the thing
    5. No complicated parts or seals to fail.
    6. Much larger, more filtration capacity and you will hold slightly more oil, which is always a plus.
    give it a try I don't think you'll go back.
    Part HP-1005 Product Specifications
    Product Style: Oil Filters
    Anti Drain Back Valve: Yes
    Bypass Valve: Yes
    Filter Material: High Flow Premium Media
    Gasket Material: Nitrile Rubber
    Height: 3.406 in (87 mm)
    Outside Diameter: 3.688 in (94 mm)
    PSI Relief Valve: 11-17
    Removal Nut: Yes
    Style: Canister
    Thread Specification: M20 x 1.5
    Weight: 0.95 lb (0.43 kg)
    Product Box Length: 3.81 in (97 mm)
    Product Box Width: 3.81 in (97 mm)
    Product Box Height: 4 in (102 mm)
    Part HP-1004 Product Specifications
    Bypass Valve: Yes
    Outside Diameter: 3.156 in (80 mm)
    Removal Nut: Yes
    Style: Canister
    Thread Specification: M20 x 1.5-6H
    Weight: 0.63 lb (0.29 kg)
    Product Box Length: 3.16 in (80 mm)
    Product Box Width: 3.16 in (80 mm)
    Product Box Height: 3.63 in (92 mm)
    Green Latern and some others have had an issue where part of the stock filter adapter casting prevents the filter from sealing properly all the way around, you may have to file or grind it (keep shavings out of the oil passages):
    Be sure to test fire your engine before letting it off the jackstands, a helper is always best.
  2. The Following 8 Users Say Thank You to Chris@Rvengeperformance For This Useful Post:
  3. #2
    This need pics installed to be relevant!
  4. #3
    haha its a mess under there right now, don't know if I want to take one, but maybe I can clean it up and grab some.
  5. The Following User Says Thank You to Chris@Rvengeperformance For This Useful Post:
  6. #4
    | @/|/| +|2()|/| verified
    December 2009
    Fox Cities, WI
    I'd also like to see.
  7. #5
    there you go fellas
  8. #6
    Man vs 3/S verified
    Kingston, WA
    Gonna buy one and try in a couple months, oil has lots of life left on it.
  9. #7
    Keeping it real...
    Oct. 2006
    Reno, NV
    Interesting. Will have to compare side by side.
  10. #8
    So big :0
    August 2010
    Chicago
    awesome. always nice to have a bigger filter.
  12. #10
    Been using the 1004`s for years now, will try the 1005 on next change.
    Cheers for the info!.
