Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
Thread: what oil are you running thread...
  1. #41
    That is the other thing to remember... Higher pressure is not always a good thing. Flow is more important than pressure. Pressure could mean a restriction hence lack of flow.
    I may have lower pressure but I have great oil flow.
    What makes you think that you have great flow? Just curious
  2. #42
    Never finishes any verified
    Wake Forest, NC
    Oil Analysis showing wear levels, No lifter tick, No spun bearing, Just general accusation really.
    Good reading here of Flow Vs. Pressure: Automotive and Industrial Lubricants - Causes of High and Low Oil Pressure
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  3. #43
    Ive noticed that oil pressure in 3s's from the point of the stock sender location is greatly a function of just oil weight, oil pump and bearing clearance, not much else.
  4. #44
    Delaware
    Maybe we should open a discussion on ideal placement of aftermarket senders for oil pressure and temp?
    Jason
  5. #45
    Wake Forest, NC
    Quote Originally Posted by vroom4 View Post
    It still has to do with pressure. Even though the sender is on the pump itself, the restriction in flow throughout the oil galleries and bearings feeds back to the sender as that is the amount of pressure that the pump is working against to pump the oil through the system.
