View Poll Results: Do I want to relocate my battery?
Voters
30. You may not vote on this poll
  • No, it's a hassle / pointless.
    10 33.33%
  • Yes, it's awesome.
    20 66.67%
Page 6 of 16 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 153
Thread: Do I want to relocate my battery?
  1. #51
    94 3500gt vr2? verified
    NC
    It's good for cosmetic purposes and a little helpful if you have a decent system.
    I like having all the extra room. Not that I need it yet.
    But I do expect headaches from the track. I haven't tried yet, but I imagine they'll give me a hard time about it.
  2. #52
    Runs on alcohol. The car does too. Not Verified
    San Francisco, CA
    OK I'm getting it now. Doing this right is a bit more work than I was originally thinking.
    Hmm a keyed switch like that would be perfect for behind the license plate...
    AEM s2 EMS | E316Gs | E85
  3. #53
    YOUUSSS TRROOOLLLIN supporter
    Boston, MA
    so, I see some drag cars with a headlight removed. do people put these switches behind the headlight and then just remove the light when they bring it to the drag strip?
    -jeff
    1992 SVX LS-L
    1996 3000GT FWD-TT
    2005 XC90 T6 AWD
    i collect parts.
  4. #54
    Headlight removal is usually for intakes
  5. #55
    Delaware
    Slim battery and be done with it...
    Jason
  6. #56
    That's correct. All power is cut. However, the only device that will get wiped is the clock.
    Well all my stereo setting would get wiped unless I ran all the stereo components' constant wires directly to the battery, bypassing any switches.
    Now let us say that we wanted to mount that into a tail light of a stealth and had the option to plug it in instead. Obviously the two main ones to the battery lead would need to connect.
    How would you need to wire a jumper for the ignition coil and switch?
  7. #57
    San Francisco, CA
    OK f*** it. I'm never going back to stock anyway; I just tore into the harness. Gonna tear out all the stuff I don't use any more and do push button start with internal / external cutoffs.
    It will either be awesome or the car will never run again.
  8. #58
    Boston, MA
    take pictures!
  9. #59
    San Francisco, CA
    And while I'm at it, keyless ignition. Cause at this point why the hell not.
    Is that any sort of rule violation?
  10. #60
    You live in LA and you want to go keyless?
