Well buying the ethanol sensor pushed me over the edge. It's huge and I want to put it in the corner where the battery is. Bye battery.
AEM s2 EMS | E316Gs | E85
Yeah I got the box and switch and everything. Might as well do it right.
I can't run around LA with a giant labeled battery cutoff switch, so I will have to find a way to hide it for the street.
Good luck with that. I have been racking my brain on how to do that. Also with GEL batteries you should not have to have a box, there is nothing to vent.
Has anyone hidden their cutoff behind the license plate like this guy? I was thinking you could make a license plate frame that would push the plate out a bit.
Also I read somewhere that it has to be on the ground side - is that for real? Would they actually check that? Mine would still kill the engine because it's before the pump feeds. Hopefully that's enough.
i like mine up front....so according to several people, that means you should put yours in the back.
Thats how it is. I remember I played hell trying to wire my brother's cut off for his dirt track car until I figured out what a dumbass I was. Switched the switch to kill ground and voila, it worked.
