View Poll Results: Do I want to relocate my battery?
Voters
30. You may not vote on this poll
  • No, it's a hassle / pointless.
    10 33.33%
  • Yes, it's awesome.
    20 66.67%
Page 12 of 16 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 153
Thread: Do I want to relocate my battery?
  1. #111
    Forum User supporter
    Bounemouth, UK
    Quote Originally Posted by Intropy View Post
    I'm gonna do an RFID system. I'm not sure exactly how I want to do it, so... a mockup never hurts.
    You may as well go EMS 4 & redo the lot
    Jeff
  2. #112
    I want the third
  3. #113
    Runs on alcohol. The car does too. Not Verified
    San Francisco, CA
    AEM s2 EMS | E316Gs | E85
  4. #114
    How will you get the driver's side wires to the motor?
    Also what do you have that popper connected to? I have mine mounted to the metal for the jack and cut the cable housing, was working but now I can only open with the key.
  5. #115
    San Francisco, CA
    Sorry I'm not understanding your question for some reason. What are you asking? Where I'm tapping in for the window controls?
    It's bolted to the sheet metal. I drilled three holes, two for mounting the unit and one for the cable to run through.
  6. #116
    Yes. Every resource that I have found states that you must tap into the wire between the driver's switch and the motor in the door, due to the instant down feature in our cars.
    I have a 530T that I decided not to use because I had no clue how to tap into the wire for the driver side window.
    For the driver side window DirectWire 2.0 lists "grn/red - grn/blk" "in driver's door"
    For the passenger side window DirectWire 2.0 lists "brn/yel - grn/yel" "in driver's door or driver's kicj panel
    That makes sense, how is the cable attached to the factory stuff? Did you tie into the existing cable or did you remove it?
  7. #117
    San Francisco, CA
    I don't have the window unit yet so it's all speculative, but presumably I will tap into the wires coming from pins 6 and 21 of the driver's door harness connection for the passenger's window, and directly to the wires in the door for the driver's side. According to a quick glance at the manual.
    I'll take a closer picture of how the pop cable attaches.
  8. #118
    That would be awesome. very curious to see how you get the windows to work. I know Toni has done it, but he never really explained how he wired it.
  9. #119
    Jan 2012
    Arizona
    You can grab them all in the drivers door.
  10. #120
    Quote Originally Posted by Streamln1 View Post
    Well yes you can, but wouldn't it be easier to get only two wires to the door vs. four?
    According to DirectWire 2.0
    For the passenger side window DirectWire 2.0 lists "brn/yel - grn/yel" "in driver's door or driver's kick panel"
    I was not wanting to figure out how to get the wires through the door.
    Also Stream can I PM you about my front stage set-up, equipment I have at my disposal and weather or not I should go active or passive?
    Last edited by 2fnloud; 08-28-2012 at 10:03 PM. Reason: So I o not come across as a peter.
