Awesome work man. Can't wait to see the final project
wit a switch installed at the shifter you could bypass the clutch switch and this would allow you to start the car without needing to push in the clutch. with your set up not really a requirement.
If you install remote start it is a necessity.
In your scenario, just another step taken out of the equation, that's all.
The only thing I don't like is having to push the start button 3 times to start the engine. Is there a way to default to one-push start while retaining the option for a (potentially less convenient) 3-push start?
Regardless, really bad ass.
What are you using for fuel prime with the push start or remote start?
