Originally Posted by
green-lantern
Check the wiring to the compressor. Also did you mess with the evaporator? There is a box above the glove box that needs to be plugged in. The compressor will not turn on until there is enough Freon in the system. How did you fill it without the compressor on? If you haven’t already, start the car turn on the AC and start filling then. It will kick on after a few minutes and start filling a bit quicker then. I think it took over an hour to fill mine last time. If you did this last summer and it worked at the time but doesn’t work this year I’d say you have a leak and it’s all leaked out.
