Results 1 to 10 of 10
Thread: ideas for turbo oil feed lines?
    Pueblo, CO
    ok, well, ever since i swapped to the 3sx ss braided oil feed lines, ive had turbo after turbo getting oil starved. I dont have the stock lines anymore, so was wondering if anyone has any ideas to get better oil feed to the turbos? Im using stock return lines, but just wondering if anone has done anything different. And has anyone ever used rubber lines, ( fitting on front turbo and oil pan, then clamp on hose?)
    Just need to figure this out. any thoughts or ideas would be great. The funny thing is these turbos live and die by oil, and the feed lines are tiny
    Delaware
    Put the stock feeds back on the car.
    Jason
    Pueblo, CO
    Jason
    ok, i guess i need a set then
    Devoted Darkling
    Quote Originally Posted by Sin'sVr4 View Post
    Stock feed are tiny too. If you do consider rubber hose, make absolute sure you route it well away from any major heat sources. I've always ran stock feeds with no issues, FWIW.
    2017 Chevy Volt: Daily Beater - More range, more savings!
    2015 335i Sedan M Sport: Replacing the 2007 335i... may it R.I.P.
    1994 3000GT VR-4: 12.835 @ 109.40 (stock injectors...) still have it... for now...
    2007 335i Sedan: Totaled while sitting at a red light...
    1997 Supra TT: Gone to the land of the Red Wings
    "The world might end the night might fall :: Rain on down and cover us all :: And drown us with the burdens of our sins" -- Shirley Manson
    "I'm very, very famous. Not a lot of people know that." -- Geoff Achison
    Pueblo, CO
    i think the stockers still have a larger diameter than the 3sx ones. anyone have those measurements?
    Well crap, I bought the 3SX ss braided feed and return lines, but they aren't installed yet. Are they junk? Can we get some input from someone from 3SX?
    Bolton MA
    How do you know they are getting oil starved? Last time I heard you were running around with the MBC slammed shut and drag racing. Not really a recipe for healthy turbo life.
    Trash Can Club
    Jan 2011
    Warren RI
    I'm running 3SX ss lines with no problem
    Sent from my SGH-T989 using Tapatalk
    You can make your own AN lines if you feel that yours are too small.
    Oct 2010
    St Louis
    Made mine out of dash 4 . . . never had a problem. Still using the stock returns.
    www.ClonedECU.com
    Get Chromed!
    1999 3000GT VR4
    Glacier Pearl White
    How To Contact Me:
    eMail: brett_farnam@yahoo.com
    US3S/3SGTO: 99 vr4
    3SI: bfarnam
