Snow Performance : Nitro Booster
according to snow performance you can add a small amount of diluted nitromethanol to a water/meth injection kit... anyone on here ever try it?
the basic go fast bits...
Tuned by Ray Pampena
Just a fun Daily Driver.
I asked Chris [NP] about this a year or two ago on 3Si, and he commented that it does work.
only pussies run nitro meth.....
well thats cool to know. hopefully he will see this thread and let us all know his experience with it and if he thinks its worth the money.
so far the only info i could find on it was very vauge to say the least. no one seamed to have dyno results for water/meth vs water/meth/nitro.
It is very corrosive I have heard.
3SNG15 Best overall
Runs 12's (12.98's!!!!!!)
My Garage
A colorado owner CK (upp I think is his screen name at 3si) had posted some results with a 75 wet shot vs dry shot. He was running EVO III's at the time. He really didn't pick up any peak power at all. What he did get out of it was spool and larger area under the curve. I want to say he came into peak power like 1000 rpms earlier and was able to push 18 degrees of timing on pump gas with the nitro injection.
I'll see if I can dig up his viral video with the results... His tests are always awesome to watch. He's a really brilliant guy.
Hopefully link works from my phone...
Nitro dyno results are shown around 8:30 into the vid.
Wet and dry results were the same. Car is a beast now with a huge 90mm single. He dropped the supercharger and undid the triple charge. He's spraying nitro, running twin fuels from two fuel tanks and driving 12 injectors. 6 for Ethanol, 6 for methanol. Plus 75 shots dry and wet. LoL, he's flippin power crazy.
YouTube - CK Colorado.
J......dont think youre on the same page as everyone.
Nitro injection, taking nitro R/c fuel and putting it in your water injection system. Has an even greater HP/cooling effect than methanol injection.
