Inners and outers are about the same cost. Not worth it to replace one and not the other though.
Jim, the problem was with my Stealth, not the Spyder....
When this started (over a year ago) I got advice from Ray/Steve that the inner bearings were most likely the cause, so I replaced them (cost per was ~ $24 per). As mentioned, it seemed to correct the problem...but alas it came back with a furry about 3 months ago...
I snagged the outer bearings off www.rockauto.com for $8.xx per bearing...had I had access to a press, other than my sweat, this could have been a really easy/CHEAP fix
My Stealth has ~ 104K, the Spyder ~ 106K.....
No issues with the ass end of the Spyder![]()
Bob.![]()
Stock 18" 6 Spoke Chromies
Indiglo Gauges
92 Wheat Beige Metallic Stealth TT (sold 6/14/20)
I just buy the whole hub assembly with bearings on it from the dealer. That way I don't risk messing anything up while taking everything apart. It makes the job so much quicker and easier. Plus you get all new wheel studs to replace those old and tired ones on the car.
Price per side Hansie?
Bob.![]()
