UPDATE:
Talked to Brett, he's got one coming my way! :thumbsup:
UPDATE:
got the wires from Brett(thanks!) and got everything together. Just checked evoscan and im able to datalog wbo2!thanks for the help!
Sorry to dig up this thread, still learning
I want to run a WB02 when I do my build. I understand I can wire into pin 93 and no gauges are needed. I'm thinking of the AEM UEGO 30-2310 which I believe provides a 0-5V output. Is pin 93 an analog to digital converter (ADC) input pin? Does Chrome let you set the scaling to match the AEM unit?
I assume I'll be able to use my netbook and log WB02 with Evoscan using the 1.3U cable, is this correct? Can I / should I use the Tactrix 2.0 instead?
Once I get my car tuned and setup I don't expect to log performance regularly.
for whatever reason I was off a bit scaling it that way, but I have the exact formula for the inline wideband and evoscan that works great
use the tactrix 2
Read the first few pages of the chrome manual. Setup, calibration and logging are all there. Yes it's and ADC input like all the others.
You can use either cable to log. The 1.3 cable will get you about 2x the packet rate of the 2.0. Don't forget to swap to the 2.0 if you flash.
Oops forgot to RTFM![]()
