Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 47
Thread: Wideband 02 with EVOscan and CHROME
  1. #31
    www.chromedecu.org verified
    DFW
    Quote Originally Posted by NOMIEZVR4 View Post
    made an offer on a MTX on ebay...waiting for a response. IDK why but since I started driving more with the 1000cc injectors I feel like my car is running rich..it blows out a fireball at WOT shifts(friend saw it)and the exhaust tips are getting pretty blacked out too...can't wait to get this wideband and start seeing whats going on with it..
    Whats your fuel pressure set at? Should be 45ish without the engine running. 35 at idle.
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
  2. #32
    August 2010
    Chicago
    Haven't hooked up a fuel pressure gauge...prior to the injectors I didn't have this issue though...FPR lines and everything else is stock minus the pump and injectors.
  3. #33
    I lack color... verified
    Aug 1998
    I haven't touched ANYTHING except for the startup tables which you did for me, injector scaling and latency tables and the periphery bits to keep the CEL's off. So to answer your question, yes.
    my complete mod list:
    .80 Wiseco Pistons and Spool Rods
    Ported heads 99 Lifters
    JDM Gear/BHB
    Fidanza Flywheel/Clutchmasters stage 3 clutch
    MTC Ported 19T's--WRX converted 13T's
    Walbro 255 hotwired/Delphi 1000cc
    Megan Downpipe/ebay 02 housings
    Flash ECU
    EVO MAF/EVO9 BOV/Intake Pipes/Filter/Hallman Pro MBC/Y-Pipe
    Stock fuel table is too rich for your setup. Go ahead and take some fuel out of it.
  4. #34
    DFW
    WHat are your trims at?
  5. #35
    August 2010
    Chicago
    Had to replace the starter again because it was a defect...so had to undo the battery again. I'll put some miles on it and report back..
  6. #36
    Did posts get deleted in here? The dates jump from July to November?
  7. #37
    Oh never mind I was confusing this with the main chrome thread
  8. #38
    August 2010
    Chicago
    Hey so I'm installing my WBO2, my pin 93 doesn't have a wire on it.(I have an adapter harness)..I had a spare harness from another car tried to see if I could stick a pin in it, no dice. I don't wanna stick the wire straight from the wbo2 into the harness connector because I don't think it will have a proper connection. What to do?
  9. #39
    you need to get a pin for the 99 connector. I have no more spares, but you might put something in the parts wanted.
    quick question related to this. Greg, is there another input we can use to log OIL pressure?
  10. #40
    Aug 1998
    Secondary 02 would be great for that.
    hmm... :chin:
