Just started doing this it's a 91 gto tt take a listen to the video and let me know what you think!
When is the last time you drove it?
If you drive it daily, you have a new club to join... Spun Bearing
If you just fired it up from an extended nap it could be a collapsed lifter. Still may be a lifter gone bad even if it has not been sitting.
Get a cheap stethoscope from Harbor Freight, or use a large screw driver to the ear. Locate the source area of the knock. That will help diagnose.
It's strange sometimes it's not there and goes away under load . I just picked up the car so unfortunately I don't know when this started. I have to pick up a stethoscope today. I was hoping lifters
Doesnt sound metallic enough to be a collapsed lifter.
Sounds bad. stop running/revving the crap out of it. Drop the pan and inspect your rod bearings.
Jason
Ok thanks again.. I'm going to do that tomorrow and will update !!!
