Results 1 to 10 of 11
Thread: 1993 Stealth RT/TT $12000
    May 2012
    Virginia Beach, VA
    1993 Stealth RT/TT $10,500
    1993 Stealth RT/TT 10,500
    Pictures by bnbovey - Photobucket
    That URL will take you right to my photbucket album to see pictures of the car
    I am selling my 1993 Dodge Stealth RT/TT it has 107,xxx miles on the body but has a JDM motor with approx 45000 miles on it, it has a lot of mods I will list off I had it retuned and redynoed about 4 months ago, it put down 513 AWHP/ 489 Ft/lbs at 22lbs This car runs great and pulls hard the motor is fresh i just dropped it in it came out of a completly stock car so it has never been pushed or stressed, this car is a lot of fun i don't want to sell but i need to at this time.
    Starting price i am going to ask is 10,500 OBO
    List of everything done to it
    4 bolt block JDM drop in with Aprox 45,000 miles on it
    Transmission was rebuilt 10,000 miles ago
    New transfer case 5,000 miles ago
    Fidanza aluminum flywheel
    3SX dual spec stage 4+ unsprung clutch
    Aluminum one piece driveshaft
    3SX TD05 Turbo kit with non MHI 16gs with Turbosmart 38mm external wastegates, I have an extra rear manifold I will send with it
    Front and rear pre cat eliminators
    3SX downpipe
    Cat replaced with test pipe
    3 inch Borla exhaust
    AEM EMS tuned for water/meth at 18lbs and 22lbs
    AEM water/meth kit 1 gallon with inline filter and new nozzle
    AEM water/meth failsafe device
    AEM Tru boost controller
    AEM A/F ratio gauge with O2 6 in 1
    HKS turbo timer not hooked up but has harness
    3SX dual pump/ dual feed fuel system with dual walboros and 3SX fuel rails
    RC 750CC injectors
    Dejon pre turbo blow thru red intake pipes with K&N filters
    Dejon Front mount intercooler with red pipes
    Turbosmart dual port BOV
    Accel 8mm spark plug wires
    NGK coppers
    3SX ball bearing short throw shifter
    Battery relocated to trunk
    Optima red top battery
    3SX solid motor mounts
    Megan racing coilovers
    AWS delete,
    Adjustable rear camber arms
    Powerslot slotted rotors
    Stoptech street performance brake pads
    Steel Braided Brake lines
    18x9 saleen replicas with brand new Kumho ecstas 255/40/18
    New paint job summer 2011
    OEM wing replaced with 1998 3000GT wing
    Interior is in good shape it is red and black
    Bose double din in dash dvd player
    Aftermarket Steering wheel
    K&N Oil Filter with Rotella 15W40
    Vaccum Reduction Kit
    That's what I can think of right now off the top of my head the car is clean it doesn't have any rust on it at all
    The stock oil sending unit sucks and will sometimes read low at idle but i got a oil pressure test done and it's good
    Stuper Moderator
    January 2003
    URL didn't take.
    Douches
    May 2012
    Virginia Beach, VA
    Url fixed check out pictures
    May 2012
    Virginia Beach, VA
    Bump for price drop 10,500 obo or 9000 obo with stock rims
    What are you wanting for the stock motor?
    Sent from my DROID RAZR using Tapatalk 2
    May 2012
    Virginia Beach, VA
    If I part the car out I am looking for 1700 plus shipping for the jdm motor I'm trying to sell the car as a whole
    I mean the old motor you pulled. I'm looking for a core.
    May 2012
    Virginia Beach, VA
    all i got on that is the block and crank girdle
    What are you asking?
    May 2012
    Virginia Beach, VA
    Pm sent
