Page 8 of 40 FirstFirst ... 67891018 ... LastLast
Results 71 to 80 of 391
Thread: Big Single Build
  1. #71
    Andover, MN
    So I made some progress. I cannot stress the importance of having the correct tools for the job... I was having difficulties with this cheapo valve spring compressor, and spent like 1 hour to get one valve spring off. So I said forget this tool and went and got an actual nice valve spring compressor tool, 20 minutes later, had all of the valves out and sorted.
    So I made some interesting revelations. The intake valve and exhaust valve are different sizes, but, the intake valve is double the size of the exhaust valve. Not sure why people are thinking these heads don't flow... But whatever. So the other thing I want to point out to is that the cylinder areas on the heads have an oblong milled out area where the stock pistons, with their oblong cut out on the surface, meet. What does this mean? While I may have deep valve reliefs in the new pistons, I need to have the heads milled out a bit to accomodate the increased piston surface area, or I am going to have higher compression ratio than stock and I am also going to have flow issues. So now that the valves are out of the heads and the heads are ready to go with the block for machining, the project is at a halt for a bit.
  2. #72
    YOUUSSS TRROOOLLLIN supporter
    Boston, MA
    are you done yet.
    -jeff
    1992 SVX LS-L
    1996 3000GT FWD-TT
    2005 XC90 T6 AWD
    i collect parts.
  3. #73
    Andover, MN
    Quote Originally Posted by sketch View Post
    are you done yet.
    I hope the have the engine and heads out to the machinist this weekend to get work done!
    Then I have to push a big order through for rebuild stuff, I am picking up the main and rod bearings tonight so I can drop the crankshaft back in the block and so the machinist can have the crank turned and balanced for the new pistons/stock connecting rods.
  4. #74
    Andover, MN
    Well I haven't received a response from the machinist as to when I can drop off the engine so I have proceeded with ordering the first large batch of parts.
    Ordered:
    PULLEY3SXSOHCBELTS 3SX Custom Crank Pulley Stock
    60KIT-3S-SOHC Mitsubishi OEM 60k Service Kit
    MD974464 Engine Gasket Kit Complete
    MD154251 Oil Pump - SOHC 91-95
    CableAccelFWD-P2TB Throttle Cable - FWD Pedal
    KnockSensorBracket3S Knock Sensor Bracket All 3S
    BOLT-0058 BOLT-0058 - M10x20 Bolt Mount
  5. #75
    Nice! Might check Ninja for faster shipping, and cheaper.
  6. #76
    Andover, MN
    I will have to check with Ninja, but I couldn't get a lot of the SOHC stuff with Ninja.
  7. #77
    Andover, MN
    I ordered the valves and valve guides from GZP. Waiting for 3SX order to ship and GZP order to ship and I will have all of the engine components spoken for.
  8. #78
    Andover, MN
    Made some small progress this past weekend, not a ton though...
    Built the modular gauge cluster panel and the modular switches panel. I will be building the center console out this week, still trying to understand how I am going to design it. I think I am going to have to wing it... It will be a 2 piece design, 1 piece per side. I also ordered some CF vinyl wrap to finish the center console out, making it look presentable I suppose...
  9. #79
    Andover, MN
  10. #80
    Andover, MN
    Alright here goes...
    Valves and Valve Guides are here.
    Waiting for more parts and CF vinyl.
