Page 7 of 40 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 391
Thread: Big Single Build
  1. #61
    Andover, MN
    Quote Originally Posted by vroom4 View Post
    Same place as the idea for the built SOHC haha.
    Everyone has a passion here with their 3/S. Mine is simply doing something that hasn't been done often.
    But doing it RIGHT. I sincerely hope that there is a genuine appreciation for going down the path of doing it right versus throwing a junkyard motor in and patching it together to work. I'm not doing a junkyard motor strap a turbo on and call it good. Building out the block correctly and doing a full rebuild on the engine, having the crank balanced for the connecting rods and lighter pistons, etc. Having it done right. I want a reliable turbo car that I can race around on the track without doing a lot of monkeying around with a bunch of tunes or changing everything out all the time. I have a power goal of double it's current horsepower rating. If I can conservatively get a little more out of it, awesome. If I don't, I can say that I have pursued something very little have but more importantly, if the setup is reliable and not much needs to be changed or tuned, I am totally OK with double the horsepower goals. It's about having fun with the car, it's not necessary to be the most powerful car out there.
  2. #62
    Driving Chris back.
    Subscribed.
  3. #63
    Andover, MN
    Wiseco custom forged pistons shipped this morning, should see them next week.
  4. #64
    Andover, MN
    Everyone really cares about pictures, so here are the camshafts and gauges:
  5. #65
    SOHC cams are so thick. Gauges look good, the analog wideband should be really nice as long as it can sweep fast enough.
    Andover, MN
    It is a pretty nice wideband to be honest. It should be able to sweep pretty quick. As long as the fuel maps are setup correctly, it shouldn't need to sweep a lot. I honestly am not really worried about changing the valve springs at this point because the springs are so beefy. The springs can really withstand a high load and I doubt they will float.
  7. #67
    Done yet?
  8. #68
    Andover, MN
    Moar pics to add! Pistons showed up:
  9. #69
    1993 rt/tt Not Verified
    wa state
    Done yet?
    lol...as if you have a lock on "most efficient rebuild ever"
  10. #70
    Andover, MN
    So I got my new custom collector's plates ordered. Plates will say "STOHC"
