You also know how it feels to drive a car that a madman zip tied and duct taped the damper back together........
watch out for that braided line in the tank. If it isn't rated for submerged use it can rot out and leak. blow your motor
I think it will be OK. It is the teflon PTFE core inside, I suppose it will be on my mind to check periodically since it is something that could lead to total engine destruction. I took a look at the specifications of the hose and they recommend checking the hose annually inside and out.
A little mini-update
I got the following accomplished this weekend:
Built oil cooler lines with additional fittings
Installed fuel rail fitting for -6AN feed line
Built turbo oil drain line with -12AN line and fittings
Installed new 1/8 NPT female to 1/8 NPT female Y adapter. Also picked up a 1/8 NPT straight through small extension fitting and installed into oil filter housing where pressure sender goes. Installed the 1/8 to -4AN adapter into Y adapter and installed Oil Pressure sensor into other Y opening. All assembled with teflon for good seal.
Partially assembled fuel hat to stock hard line -6AN line with 1 -6AN fitting. Awaiting an additional -6AN fitting.
Also waiting on -12AN weld on bung for oil pan and a 1/4NPT to -4AN adapter fitting.
Hey, Kev - umm, maybe have yer missus take some pics?![]()
Hmm, maybe tomorrow I will post some pics up as I need to spend some time just snapping pics.
At this point, there really isn't a whole lot more I can really do until I pull this engine out. I suppose I can work on some electrical wiring and start getting some of the essential fuses moved to push button circuit breakers in my circuit breaker panel and start getting the panel created and vinyl wrapped. Maybe work on building out the dash.
Yesterday I got the radiator fans installed on the radiator, dropped the fuel pump assembly in place.
So two small things accomplished today. Got my three fittings, finished up the fuel bulkhead to stock hard line run and installed the line and installed the 1/4NPT to -4AN adapter fitting into CHRA housing on the turbo.
Someone say Shelly![]()
Just make sure she takes pictures of the car instead of just a bunch of pics of you lol.
