Page 30 of 40 FirstFirst ... 202829303132 ... LastLast
Results 291 to 300 of 391
Thread: Big Single Build
  1. #291
    Andover, MN
    Looks like I might be getting what I need from a guy off turbo-mopar.
  2. #292
    Andover, MN
    So while cleaning the pole barn, I found the missing spring for the camshaft assembly so I will put that on soon.
    Not really care related, but thoroughly cleaned the pole barn and moved the car a little bit:
  3. #293
    VR-3747 :D Not Verified
    Dayton Ohio
    wish i had that much room to play with
  4. #294
    Andover, MN
    Here's what I did on Sunday, not really much of anything, but fabricating the heat exchanger mount to the frame was a big deal. Cleaned up a few parts, cleaned the oil pan a little but debating on what to do with the sludge in the pan. I want to put something in the pan and let it soak up and break up the sludge. Not sure what I can use to do that, any suggestions?
  5. #295
    Small ginger penis joke here.
    pardon my ignorance, but is that "thing" coming off of the oil filter the oil pressure sensor?
  7. #297
    YOUUSSS TRROOOLLLIN supporter
    Boston, MA
    looks like it, yeah.
    -jeff
    1992 SVX LS-L
    1996 3000GT FWD-TT
    2005 XC90 T6 AWD
    i collect parts.
  8. #298
    Yeah thats where the oil pressure sensor is on the SOHC.
  9. #299
    Andover, MN
    The stock sender is a placeholder for that spot for now, I need to get a special line run for that to the turbo oil feed. I also need to drill and tap the pan for the return line while I have the pan off.
    I was mocking up a few things:
    Pesky oil pump seal kept rolling over on itself, will need to use oil to lube the seal and prevent it from binding.
  10. #300
    Hurry up! I have curious thoughts...
