Well, things are starting to ramp up again. Will be doing tons of car work this weekend. Ordered Milspec connectors for the engine harness and circuit breakers to replace fuses. It will be a nice little wiring weekend. I am hoping to start really tearing into the car now.
I just don't have a great feeling about that balance job, but the rest of it looks good. The cylinder wall finish looks good
Kevin, I'm gonna say this as a noob with no personal experience inside the crankcase of this platform (I also wish to assure you I mean no offense) - it that thing stays together, it should fly.
If it doesn't, that ^^ is where it will likely fail.
Again, I'm rooting for you, not the Japanese engineers.![]()
Hype Hype Hype!
Engine comes home tomorrow evening. Everything is done and ready to go. Tomorrow we are going to drop the cams in to make sure they will fit through the bore and see if it will need a line bore through the cam caps.
Other than that, everything else is good. Will be snapping pictures tomorrow.
Woo! it'll be running by this weekend, right!?!
Looking good Kevin, the new camera is a big improvement.
Shortblock is back. Now it's time for assembly!
Oh, and we dropped the cams in the new heads and put the camshaft sliders, rockers, caps on and tested the camshaft rotation. Camshafts rotated with no effort at all even with the bolts tightened down so no need to line bore the heads.
