Page 18 of 40 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 391
Thread: Big Single Build
  1. #171
    Ann Arbor, MI
    Hurricane Wheels! Yes!
  2. #172
    Andover, MN
    Clutch kit arrived:
    Also almost all of the parts shipped from 3SX, still waiting on an Odyssey battery, but everything else should be coming.
  3. #173
    Andover, MN
    I'm really trying to get as much as I can done on this car, but it is very difficult when it's below zero most days. Even the heater doesn't really help that much when it's below zero. I did miss the one good day this past Sunday it was in the 30s, but I decided that it was best spent outside with the gf.
    So what I am hoping to accomplish in the next couple weeks or so:
    Remove ABS Lines and ABS Pump
    Order ABS Delete Kit
    Install ABS Delete Kit
    Remove Radiator and swap the fans
    Remove Air Conditioner condenser
    Reinstall Radiator
    Install Icebox
    Install icebox drain valve and tubing through passenger floor
    Install water lines through firewall
    Install Intercooler water pump
    Pressure test intercooler core
    Decide on heat exchanger core size and order
    Create ducting for heat exchanger and install heat exchanger and heat exchanger fan
    Drop the downpipe and pull full exhaust off car and sell
    Sell CarPC setup with speakers
  4. #174
    You have ABS on a SOHC?
  5. #175
    YOUUSSS TRROOOLLLIN supporter
    Boston, MA
    according to his photos, he does, yeah.
    -jeff
    1992 SVX LS-L
    1996 3000GT FWD-TT
    2005 XC90 T6 AWD
    i collect parts.
  6. #176
    Yeah, after I posted that I went back up to see if the photos showed the lines or not and was shocked to see them.
    I agree, ditch the ABS.
  7. #177
    Andover, MN
    New heads are coming, should be here tomorrow. Then I can send them to the machine shop and have the guides and stem seals pressed in as well as cleaning the heads and doing some exhaust porting.
  8. #178
    Andover, MN
    Flywheel bolts and pressure plate bolts arrived along with everything else. Dropping off clutch kit with bolts to the machinist today and hopefully tackling some work on the car.
  9. #179
    Andover, MN
    I dropped off clutch kit with flywheel and pressure plate bolts to machinist. Pretty wicked weather today.
    Well I got some things taken care of on the car, but some bad things happened...
    I pulled the radiator, air conditioning condensor, lines and installed throttle cable without cruise.
    I tried to salvage the radiator since it seems to be in decent shape, however, the radiator fan bolts were rusted bad and I could only get 3 of the 4 on both fans. I pulled the fans off and one pulled the mounting tab on the radiator creating a hole and the other one broke off at the ear. Looks like I need to add a radiator to the list.
  10. #180
    Shouldn't be too hard to pick one up from the classifieds. I know mine was absolutely trashed when I pulled it out
