Non-OEM knock sensor?
SOHC doesn't come from the factory with a knock sensor. Only the 10:1 Diamante SOHC's came with knock sensors.
Engine builder/machinist came back with invoice. Proceeding with adding ARP Main studs and head studs for strength and durability. Once clutch kit comes in, sending everything off to the machinist and getting the block back in a few weeks!
I got the whole intercooler setup minus the heat exchanger. I didn't get the heat exchanger yet because I need to pull the bumper off to get an idea on what kind of room I will need.
Did some work on the car last night.
Had a friend come over and help with some stuff.
Removed the hood, charcoal canister, throttle cable, all intake parts, coolant bottle, outer fender bolts. Removed solenoid rack on the firewall and charcoal canister line, hard line is removed too.
I then did a quick mock-up of the intercooler and turbo locations.
Geez, that thing looks massive, even down there. I like how short the intake piping will be, should have great response.
Machinist said block is out getting all done up. Shot peened, magnafluxed, cleaned. Once it comes back it will be getting decked, line honed, bored, pistons hung, clearanced, and crankshaft turned, balanced, cleaned.
