Page 11 of 40 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 391
Thread: Big Single Build
  1. #101
    Rochester Hills, Mi
    I'm guessing there will be some modifications needed to make up for the different angles of the exhaust flanges and maybe even the distances between them. I bet the SOHC flanges are closer together than the DOHC. I'm just guessing though.
    It should still be easier than starting from scratch lol
    95 Base 3k: 6G74/TT/AWD conversion
  2. #102
    Andover, MN
    Quote Originally Posted by Uniuno View Post
    Actually the spacing is the same from what I have seen. I will just need to weld very tight and it should be fairly easy.
    DOHC:
    SOHC:
  3. #103
    Andover, MN
    Project is on hold, buying a house... closing date is December 6th.
  4. #104
    Quote Originally Posted by Boost4VR4 View Post
    no kidding? I'm closing on one on dec 4th.
    It certainly puts a "hold" on some projects, lol. Gotta tow my car to the new place haha.
  5. #105
    Andover, MN
    Yea got a decent deal on a house here in MN. Not moving that far really, 20 minutes away, but now I own rather than rent. It's a seller's market here in MN, and it's been a very tough 3 months trying to lock in on a house. New place has a 40x30 pole barn and a hot tub building sitting on 1.5 acres, can't go wrong with that!
    I gotta tow my car to the new place too. Engine is still sitting with the machinist, in a few weeks I am sure I will be getting a phone call asking for money or parts for the engine block. I still have to drop off the flywheel to the guy for the crankshaft balancing and call Ray Pampena for some connecting rods as well as a new set of heads since mine are cracked, likely going with Hans from GZP as he has a virtually new set of heads for a really good price. Those things I plan on getting after the move and everything settles down...
  6. #106
    Andover, MN
    I did the unthinkable this morning...
    Borg Warner s366 turbo ordered...
  7. #107
    Andover, MN
    Everyone cares about pics... Here they are:
    Muahahahaha!!!
  8. #108
    Sweet! That should be a blast
    Sucking in MiniSoda...
  10. #110
    Where ya puttin the engine?
