Results 1 to 5 of 5
Thread: Electrical Issues
    Ann Arbor, MI
    Electrical Issues
    Have a couple of issues. Just started driving this car for the first time. 1991 RT/TT.
    1) Brake light fuse keeps blowing. It will last a couple of hours then blows and I lose the brake lights.
    2) Stock head unit/radio is making a popping sound over the speakers after having the radio on for a few minutes. If I turn off the radio then turn it back on the popping goes away for a few minutes.
    Any ideas?
    Rochester Hills, Mi
    Sounds like a noise canceling capacitor is going bad somewhere.. Is the little guy still there by your coil pack still intact? If resetting the radio temporarily fixes it there might be a capacitor inside that's failing.
    I'm not sure if anything else shares the circuit for the brakes.. I'll check DealerConnect to find out.. sounds like something besides your brake circuit is failing, or maybe high resistance in the bulbs?
    Did you take a DVOM with to the NG? I'll bring mine with..
    Rochester Hills, Mi
    DealerConnect is less than helpful on a 1992
    I could only get a few diagrams on a '96, I'll email it to you.
    Maybe Stealth316 has something?
    Canaan NH
    Wish I could help you Alex. For the radio you could check it without the car running, see if it still pops. For the brakes, I wonder if someone has the wrong light bulbs in it? You could also try disconnecting the 3rd brake light to see if your problem is there.
    Ann Arbor, MI
    Thanks for the wiring diagram Josh.
    Corey, I figured it out!
    Brake lights: I assumed the fuses were popping, turns out they were just "loose" in the fuse box. I slightly bent a prong on a fuse so it would stay put, all is well now!
    Radio: Previous owner rigged up the speaker wiring in the doors. The driver side front speaker wire was grounding out on the speaker frame and causing "pops" when the car drove over roughness in the road. All is fixed for now. Lucky!
    Thanks for your assistance guys.
  6. The Following User Says Thank You to Alex3000gt For This Useful Post:
