Results 11 to 20 of 33
Thread: cel 41, no RH O2(front?) only in some cases.
    Maybe I will bring my DMM up there this weekend and help you out. Saturday morning?
    Madison Heights, Mi
    I'm thinking the scale is off. 33 is probably really 3.3
    Touching the probes to each other nets a 0.0xxx numbers. If I use the clip I get a similar low number.
    Saturday would be too late. If I can't sort this and have it stable tomorrow night early sat at the latest. its not going and the SL will.
    I said saturday morning, I can leave as early as 6 am. If I can get ahold of Larry I may be able to bring a 450CC injector.
    Madison Heights, Mi
    Whats a DMM?
    Fowlerville, MI
    Alan, have you tried just swapping injectors and see if the code follows the injector or stays with the circuit?
    Madison Heights, Mi
    NO, I have not tried swapping them
    Madison Heights, Mi
    Checked again. #3 is giving the same numbers as the other injector now. CEL gone car runs smooth.
    I'm calling it as the injector. Anyone got a blue 450cc injector and can get it to be my sat morning?
  8. #18
    I have some but shipping may be expensive.
  9. #19
    Madison Heights, Mi
    overnight with sat am delivery yea that would be a bit much.
    Hopefully someone local has one.
  10. #20
    Larry has a 550cc. I can try the the Junkyard tomorrow but you should try DSM graveyard, they will pull it for you, i'm sure they have one.
