I had a cylinder that would misfire, after going through the ignition system and changing plugs and wires with no resolve I sent all my injectors off to be cleaned and tested, they all came back "good" yet I had the same misfire issue, switched the injector to a different cylinder and the misfire moved to that cylinder, replaced that injector and now all is well. So sending them off might not be that beneficial.
Pearl White 1999 VR-4 #164
its worth a try, it cant hurt.
1991 Stealth RT/TT forged crank, new pistons/bearings/rings, T16's ceramic coated, precat deletes ceramic coated, full exhaust, FMIC, Dijon intake pips, adjustable cam gears.
If you have bad injectors, sometimes flow testing them will turn up good, but the injector does not pulse causing either a full open or full closed condition. The above described methods will help determine if you have injector pulse.
well i know that i dont have a stuck issue bc i checked each one and they all put out the exact same amount of gas.
No but you can have a full open condition which would make that cylinder run rich and cause WBO2 readings to fluctuate because 1 cylinder is rich.
here is what i am saying. i tested all 6 injectors at once. they were attached to the fuel rail but not to the intake manifold. if one was stuck open that one would have put out a LOT more fuel than all the rest of them did. at this point its either a spray pattern issue, or there isnt really a bad injector and the person that sold them to me just thought there was.
Yea a full open condition wouldn't be a big deal at all unless you are tuning. I wouldn't really worry about it, if it works, it works.
thats the issue, i am running a full new motor/turbos/injectors/fmic. tuning is what i need to get it all running right.
