Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: clutch issue
    clutch issue
    ok..
    i have a issue with my clutch/gearing now..
    i was backing out from my garage and when I put it in neutral it kept backing up slow..the gear didnt disengage properly.
    I have noticed that I dont get the same pressure when on the cluch pedal as I did before. I checked the fluied, thats still the same.
    I have no problem changing gears, but when releasing the clutch pedal I can shift from one gear to another without using the clutch..Im afraid to go out driving and finding myself without the possibility to change gears, or put it in neutral at a stop.
    What can I be looking at here? What should I be looking at?
    I have a 92 Vr4, with a sinter cluch..
    Feb 2011
    NE oHIo
    You are not getting a full release of the clutch. The most common cause is adjustment of the clutch master cylinder. Next would be a CMC/slave going bad. Least possible but still probable is a broken pressure plate.
    -SP
    Dandridge, TN
    I'd start by adjusting the clutch pedal play.
    Ok so I adjusted the free play..found out I did it the wrong way and had to do it over again :P But it did make some difference on the feeling of the cluch. But the gears can still be changed without using the clutch..I havent run the engine or the car after the change, do I have to do make this work?
    sometimes I wish I was a mechanic, and knew what I was doing :P
    Banned J. Fast's Avatar
    If you pump the clutch pedal does it get stiffer or does it keep the same pressure? Pump it like 10 times consecutively and then recheck the level. The other thing you might check is the counterweight on the transmission and see if it's getting blocked out from intercooler or radiator hoses.
    Pueblo, CO
    are you changing gears without pressing the clutch with the engine off? Becasue you dont need the clutch with the engine off.
    I am doing it without the engine running :P I seldom get some time to check anything..with a nagging wife and screaming baby craving my attention all the time :P Will have to continue the checks tomorrow.
    Thanks for the replies so far
    Uh, yeah, if the engine is running you don't have to depress the clutch pedal to run through the gears since nothing inside is spinning.
    jupp..adjusting the free play fixed the problem
    however..why is the car stalling when shifting from 3rd gear to 2nd..or just slowing down to get into my driveway and having the cluch engaged..bad alternator?
    Canaan NH
    Your IAC has gone bad. Get it fixed soon or it could damage the ECU.
