Which 5th gear are you talking about? Manually lists two, one on the intermediate shaft, which is the small gear and one on the input shaft which is the larger one.
2013 January Car of the Month - All 3s
2011 November Car of the Month - Interior
If my links/photos don't work replace penguinhosting.net/~bigmac with primaryboost.com
Uncut 3000GT keys for sale! Various colors!
I believe I used my bearing splitter to grab underneath the gear to press the hub off.
I don't think I could do it any other way with the tools I had since that gear is recessed. I've done this twice on two separate trannys. Might not be the best method but it worked twice.
How are your teeth doing?![]()
haha haven't messed with it, had to work. Going to take it apart later tonight though, I'm sure it will be ok. I may heat the bearing sleeve a little. Last syncro to replace and I can get the shafts back in the case. Wasted some time last night trying to get one of the counter shaft snap rings into the into the input shaftThey are quite a bit thicker, thought the gear wasn't pressed enough, whoops! I'll use a different snap ring then that poor guy I tried to stretch over the input shaft.
Hasn't been a bad job, but I've been waiting a while on the parts for 5th.
shifts like butter, seriously like brand new, better than I thought it could.
Nice! Yeah I had the same feeling after doing mine. I was like wow, so this is what not grinding feels like lol.
