Here we go again with the air under the car thing. With a splitter air will probably not ever see those shrouds. Be better off going back to the hoses.
So what's structural about aft the front strut towers? Pretty sure nothing unless you have a crashbar? Don't even need the front motormount or the front crossmember. Was a full day to build actual functional brake ducts proven to work on a championship cup car too hard? I don't get it?
Sometimes solutions take hard work and time. I keep seeing quick and cheap fixes and this cycle of failing over and over because it would require hard work or take too much effort and time to fix it right. Why not just put the time in out of the gate so you can spend it doing something else later?
Those shrouds won't work on racecar with undertray Erron. You have to physically direct air to them. As a matter of fact, you have to consolidate and direct air to everything you want cooled. You can't just throw your thumb out and say, "go that way".
Please don't be offended by my criticism, E-Dogg, we're good friends. You gotta quit hitting the "easy button" and put in the hard work for the results your after. Don't worry, my car is done and yada yada yada... I'm going to put a whoop on you at the track if you run this cheap fix stuff, watch.
I will post up how to convert our frame rails into functional brake ducts. Mine are done. When I get some time I'll snap pics and post a writup in this thread.
