Update
10/4/10
Fits perfect added a Twin Turbo Logo. I haven't installed it yet but you will drill a hole and add this mount, which I will provide.
With an added option the whole will have CF backing like this.
Update
10/4/10
That looks nice!...They definitely need backing though.At least I wouldn't get mine without it.
the backing came in today from my vendor, I am very impressed with this quality. It is dry black carbon fiber and you can feel the texture.
Ok so in my case, where the door material itself seems to be falling apart near the screw holes, this would be perfect. BUT, will it interfere with normal removal of the door panel itself? I seem to take mine off frequently. My window keeps getting broken. I wish they made polycarbonate replacements. Also, can you make a set with no writing on them?
Absurdum est ut alios regat, qui seipsum regere nescit
"De Oppresso Liber" - "Nous Defions"
You do not need to remove your door panel to install these. Pretty much you drill a hole into your door big enough for the toggle screw to get in. You put the bolt through the piece and you put the toggle on the other side of the bolt. You then close the toggle and snap it in where you just drilled and screw the bolts in. If you need to remove your door you simply unscrew the bolts and the toggle will fall on this inside but you would take the door panel off as normally and just retrieve the toggle and install it back again as normal.
I plan on making a set with out a logo.
Oh I just saw the picture. Those look like standard butterfly anchors. Will you continue to have the CF inlay? Do you have a price estimate including the inlay?
I am looking at an added 20 dollars for the Carbon fiber. You can feel the texture/quality and it looks amazing. Pictures don't do justice until you see for your self. I will be sure to get installed pictures tonight.
MSRP pricing will be
80 for no logo
100 for logo
Add 20 for CF.
I'd jump on these
only interested if you can do "G T O" in anodized black polished aluminum. i refuse to have anything silver anywhere but my engine bay.
I'm in for the twin turbo with carbon fiber.
Are you pre-installing the CF? I want to paint the trim body color, so the cf will be an issue if pre-installed.
I also want the upper section as well that were in your friends car, which I want to say VR4.
Edit: Make it happen!
