Up for sale I've got a 1993 Dodge Stealth RT-Twin Turbo.
116k on chassis. 500 on all mods/motor
Here's a quick summary and I'll go into more details below:
New built shortblock, pampena heads, MTC 13G's, Rebuilt Trans and more!
Now for specifics:
Engine:
-4 Bolt w/forged crank and connecting rods
-Built by Side Street Motors (6 month warranty)
-New .040 forged pistons
-Block was boiled, magnafluxed, bored
-New Oil Pickup, New OEM Oil Pump, New OEM Gaskets used for entire motor, All Timing belt, tensioners, water pump, etc were all replaced with OEM parts.
Heads
-Pampena Motorsports built heads
-New Valve Stem seals and any worn valve guides replaced as needed
-Valve Job
-These did not need to be decked so he did not do them
-New OEM 99 Lifters installed
Turbos
-Midwest Turbo Connection TD04 13G's
-All new internals parts and fully balanced
-CHRA and Turbine Housings high temp coated
Exhaust:
-Stock Catback with test pipe
Fuel/Ignition
-MTC 500cc injectors
-Apexi S-AFC II Fuel Controller
-Walbro (not installed)
-9mm Iridium Wires
-NGK V-Power Power Plugs
Transmission and TC
-Rebuilt 25 spline transmission
-Shifts like butter (aka really smoothly!)
-Transfercase has new bearings and has new seals as well
Clutch<
-Spec Stage 3 Six Puck Clutch
Brakes
-New Pads and rotors 8k miles ago
Interior
-Front seats could stand to be recovered.
-dash vents are of course cracked
-Custom bezel for boost and one additional gauge as well as SAFC
-Radio not installed but comes with a Dual CD player already wired.
Exterior
-Dark Green Metallic
-Rust Free
-Repainted 4 years ago, paint is in excellent shape with a few minor dings that could be PDR'd
-18 inch American Racing Chrome rims (near center caps has some pitting and slight peeling)
-I've got the foglights and they are included but I don't have them currently installed.
With the rebuilt motor, transmission, turbos, fueling, and all the other items that have been rebuilt or upgraded this will make a fun, reliable, and fast Stealth for someone!
Asking 8450.00 obo
Thanks for looking
Dan
6l2-747-9O6l
