Results 11 to 20 of 25
Thread: My new single turbo toy.
    It is an Auto. Has 285/70/17's. Here is my driving style. Get it to speed, set cruise. I usually never go past 65 (max speed on my route to work).
    TD04 Upgrade & Billet TD05 Upgrades
    Hudson, WI
    Congrats on the purchase! Has the turbo been replaced in it?
    Out of all diesel truck turbos we rebuild we see more of the Fords then anything. Probably 10 Garrett TP38's for every one holset or S300. Regardless if its been replaced or not I hope your truck provides you with years of dependable service!
    Thanks!
    As far as I know the turbo hasn't been touched. But when it does go. You know who I will be sending it to
    GREASE BUNNY
    VA
    Nice looking truck for a 01.
    Hope you have fun with it.
    I've always loved my trucks.
    Picked up some new tires for the truck. It's amazing how much better it feels to drive now.
    Next on my list is to find out why I am only getting 11-12 mpg. I don't drive like a maniac or anything. Just straight down the highway to work and back.
    I get about 200-220 miles per half tank, which seems odd to me.
    Anyone have experience with these 7.3l's?
    Ya that is definitely low, I would get it checked out to see whats going on.
    Current:
    1972 Chevy Nova
    2004 Ford F350 Lariat 6.0L
    1991 Stealth TT FWD
    1962 Volkswagen Beetle
    Previous:
    1994 Stealth RT/TT
    1999 3000gt SL
    1973 Volkswagen Super Beetle
    1976 Jaguar XJ6
    1991 Chevy S10
    2000 Ford focus
    Stuper Moderator
    January 2003
    Okay, then yeah that's definitely a little on the low side. Not terrible, but could be better for sure.
    Douches
    I want to run a boost leak test on it. Guess I should go build a tester lol.
    Post via Tapatalk
  8. #18
    2.4L FP Black Evo VIII
    Hudson, MA
    7.3's normally get 21-22mpg highway, but it does have 250k+ on it. She could be just getting tired.
    1991 Dodge Stealth R/T Twin Turbo
    [B]MODS|ATR Downpipe|ATR Single Shot|DR650's|AEM WB02 Gauge|Ek2mfg Fuel Rail Loop|Polished Fuel Rail|Wrinkle Black Intake Mani|Mirror Red Valve Cover|Ohio Bob Short Throw Shifter|EGR Block Off Plates|Vac Reduction|Evap Delete|Cruise Control Delete|A/C Delete|E2kmfg Poly Mounts|Hotwired Walbro 255lph FP|Tein Coilovers|18x9 Saleen Replicas| 265/35/18 Sumitomo HTR II|New Shortblock|Rebuilt Heads|DSM SMIC|South Bend Stage 4 FE| SOLD
    2004 Evo VIII MUSE MotorSports
    MODS| Muse UICP| Coilovers| MBC |Muse 02 Dump + Turbo Back Exhaust| GSC S2's |Fidenza Adj Gears| Muse FMIC| FP Black| FP 84mm Intake Pipe| 2.4LR Block| Comp Twin Disc| Shep Tcase| FIC 2150's| MAP Intake Mani|
  9. #19
    Looks like I will more than likely be doing this this weekend.
  10. #20
    1. get a custom tuned chip to your ECM code. skip all the generic tuners as all they do is trash transmissions without getting you half the power or mileage.
    2. keep the boost under 25 lbs, and don't surge it. turbo will last forever. I'm talking over 500K miles easy. They are cake to rebuild yourself if ever needed since the wheels are individually balanced on the GTP38.
    3. if you tow, upgrade the transmission cooler to the factory 6.0 one. Bolts in and is like 4X the size of stock. In fact, just get one anyways.
    4. grease your front wheel bearings using the ABS sensor hole like every year or so.....they'll last forever if you do that.
    5. Moog has greasable ball joints for pretty cheap, but the upper joint requires stub shaft removal to grease it.....do it anyways.
    6. fuel mileage is all about acceleration. there's a LOT of mass there to get moving, so take it easy.
    7. if it has a K&N drop in filter, remove it and install a stock one or a better filter. Most turbos I've seen die are a direct result of K&N drop in filters or guys surging the hell out of the turbo.
