Results 1 to 10 of 20
Thread: Easiest way to pull rear head/turbo
    Never finishes any verified
    Wake Forest, NC
    Been having some coolant loss issues lately and tracked it down to a bad head gasket. I decided against pulling the engine since I didn't want to deal with it all and the only engine stand I have is currently in use.
    Last time I did the heads the engine was still N/A so no turbos. I got the front head off no problem and didn't have to remove the front turbo.
    For the rear I am wondering the best approach? I'm pretty sure I can't unbolt it from the header like I did the front. Thinking I need to remove the rear turbo first then the head. Am I correct in those assumptions??
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    West MI
    Unbolt the precat pipe, push it to the side. Pull the head with the turbo/manny still attached. This won't save you but a few minutes, so your call really
    92 3000GT VR4
    Matt
    San Francisco, CA
    I'm pretty sure I pull it as a single unit, with precat and oil drain still attached to the turbo. IIRC stock there's some little bracket that also holds the precat to the block or something, so be sure to get that.
    AEM s2 EMS | E316Gs | E85
    Wake Forest, NC
    Good to know I can pull it all as one unit. Pretty sure I don't have those precat brackets on so makes it a little easier.
    Thanks!!
    From personal experience you will actually save time by pulling the engine. I cussed pulling heads on an engine still in the car. By the time I was done I could have had the engine yanked, heads pulled, new heads installed, entire assembly reinstalled and running quicker than just pulling the heads with the engiine in the car.
    San Francisco, CA
    ^ It's true, "pull the engine" is pretty much step #1 for me now. Part of the reason I hope Nelson's motor plate group buy goes through - damn that would be nice.
    Wake Forest, NC
    Well so far I have only spent 3 hours and got everything off but the rear head. Figure about 30-45 on the rear head and I'm back to reassembly. Not to bad all in all.
    My other issue is I don't have anyplace to store the engine while its out. So sitting in my driveway with all the rain we have been having would not be ideal.
    If it were a DSM I would already be on reassembly in 3 hours.
    I learned my lesson the first time, hope it all goes well.
    Riding topless!! verified
    Owned 8 3s since 2005.
    Corpus Christi
    I've done it both ways and I'm saying pulling the motor is the best way to go. I've got it down to a few hours after so much practice.
    Otherwise with no engine hoist then pull the turbo/mani with the head. Count on a few busted fingers. Good luck.
    San Francisco, CA
    I need an engine hoist just to pull the rear head + turbo + precat. Maybe I'm a weakling but that shit is HEAVY, especially trying to dislodge it and get it up, over, and out.
