Results 1 to 4 of 4
Thread: 1992 86k 3000gt vr4 $$8750
    1992 86K $ $8750 Car is located in NorCal
    1 in million. I originally purchased this car because of how solid it was. You can do a lot of things to a car but not how solid and tight it is is one thing you cannot. I am the 3rd owner 1 1/2 yrs, 2nd owner 1 1/2 yrs. original owner 17 yrs. It's an original Cali car, no rust or corrosion, it even has all the original factory undercoating on it. OK on to the good stuff. Car is silver.HPIM1359.jpgHPIM1354.jpgHPIM1356.jpgHPIM1357.jpgHPIM1359.jpgHPIM1354.jpgHPIM1356.jpgHPIM1357.jpg
    Pros....
    1 86K mi.
    2 25 spline
    3 Fresh stock clutch 8K..... TRANS SHIFTS LIKE BUTTER !!!
    4 Fresh brakes 8K
    5 All Redline fluids
    6 Fresh 15Gs 4K Car NEVER boosted over 9 psi !!! I know because I took the restrictor out when the new turbos were put in.
    7 SS turbo back dp to stock exhaust no cat. Have complete exhaust to go with car.
    8 Tires 80% f 65% r
    9 Interior is a 9.5 out of 10. looks like it's never been sat in except for 1 qtr size spot on bolster which I believe came from factory
    10 Car was never beaten on or tracked. Original owner was an attorney in SF.
    11 Safc 2 and Innovate WB
    12 510 inj. I have original 360s to go with car
    13 Exterior is 9 out of 10 6 dings paint is fabulous.
    14 Fresh alignment
    15 Car wired for stereo with upgraded speakers in front and back with tweets in doors. no amp, bass or head unit as owner kept that as part of car sale, but do have 1/2 of original stereo set up (cd changer but have perfect Mitsu ( Eclipse) radio to go with car. All work done by Frys.
    16 All receipts except for brakes which was lost.
    17 255 Wally not hw
    18 Never tracked........that's not my thing.
    19 AC is ice cold
    20 40k on front struts 80k on rear
    21 New carrier bearings. As it turns out it did not need them as the problem was traced to a improperly balanced tire, done twice.
    22 60k service done at 55k by dealer All Mitsu parts
    Cons
    1 Cracked vents in dash
    2 front aero wing is missing but everything thing else is there.
    3 Needs antenna cable
    All work done on car was done correctly with only the best parts. This car has never given me any problems and I would not hesitate to drive to the east coast. I have seen a lot of VR4s and this one is deff in the top 20% in the country. $8750 and it's a steal at this price. PMs please.
    Driving Chris back.
    Do like.
    There is no such thing as a 23 spline. Its either 18 or 25. If you are counting 23 spline you are probably counting the axle splines.
    I thought the same thing and you live!
