Originally Posted by
ibsorgn
I run a 1st gen ECU with a supercharger set up and have done so for over 3 years. I have done all the research and subsequent wrenching myself so I speak from personal experience.
1.) You will not run lean, in fact you will run rich at high throttle operation
2.) At low throttle I've run my SAFC with negative values partly because to increase my fuel economy and mostly because the ECU favored the rich AFs
3). At cruising speed, about 2700rpms, I detect no knock
4). I get no CEL light with my SAFC
5) The 1st gen ECU gives you a stock, unchangable tune, which favors rich AFs for engine safety which supports manufacture warrantee.
After installing my 1st gen ECU along with the supporting fuel system, I felt that the tune was ideal (however slightly rich) for my mods. Engine was very peppy and very little knock was detected.
If one can be satisfied with a stock tune there is absolutely no need to go to the expense of a later model flashable ECU unless you have plans for the fuel system, more aggressive tuning etc.
Look, supercharging is just another form of forced induction, I guess you can say the ECU is tuned for turbos but that's like saying bears shit in the woods, Bottom line is the ECU accepts, air flow, rpm, knock, O2, temp signals etc to pull values from fuel and timing matrices to operate the motor, I don't think it cares how the air is pushed/pulled into the motor. Maybe if more air is being feed into the motor that what the ECU is programmed for, that could be a problem, but IMHO, you stay below one atmosphere your not going to have a problem.
BTW Blown, I intrepreted nothing you said as rude or unfriendly, those that did are just ultra-sensetive Nancy boys.
