Results 1 to 6 of 6
Thread: Transmission issues
    Transmission issues
    Alright I just swapped in a 3.5 into my ATX 93 3000gt. The and runs and drives but the tranny is in limp mode and there is a CEL. I don't have an analog multimeter to pull the codes, nor can I find one for sale. I've been to a couple of different stores all they had were digital.
    Any suggestions? I bought the car with a blown engine so I don't know the shape of the trans, but it looks clean on the exterior and it had a new Torque converter, I drained the fluid to reseal the pan and the fluid was dark. I read that there are two plugs that are easy to get switched up on top of the trans so i'll run out and try that in a min.
    I have a spare TCU from a 94 that I could swap in too. I'd just like to hear what you guys have to say. also sometimes when I go to crank the car I trip a relay or something and every light in the dash goes dead and nothing works. I unhook the battery and reconnect it and all is good.
    According to a thread I made the other day
    http://www.3sgto.org/f2/atx-limp-mode-8637.html
    Check fuse #7 just for s&g.
    As for an analog voltmeter, they are still out there.
    RadioShack® 17-Range Analog Multimeter - RadioShack.com
    Alright. I found an analog multimeter. I pulled the ecu codes I had a code for the airflow sensor (which was unplugged... DURP), Intake air temperature sensor, and for the coolant temp sensor that wasn't on the 3.5 water neck.
    SO. I hooked the analog multimeter up to pin 6 and 12 to pull the transmission codes and the needle did not move it all. I reversed the leads and still nothing, so I guess swap in the other TCU and see what happens?
    If you are getting no base code check fuse #7 as suggested. Exact same thing happened on Roger's car.
    Known as SLGuy
    Owens Cross Roads, AL
    I am going to assume that when the car is in limp mode, solenoids A and B in the transmission in their normally rested position puts the transmission in 3rd gear (limp mode). When no power is going to them from the TCU, no power is going to the solenoids. If so, a fuse can definitely be the culprit of the problem as stated already.
    Quote Originally Posted by PaulL View Post
    In the thread that stealthee posted I think I read that if the OD light illuminates when you use the switch then fuse #7 is good? The OD light illuminates so I assumed the fuse was O.K.
    I'll check when I get home just in case.
