Page 8 of 10 FirstFirst ... 678910 LastLast
Results 71 to 80 of 100
Thread: The ORIGINAL VR4 Clone™ ECU!!!
  1. #71
    Oct 2010
    St Louis
    The active exhuast, the active aero, the suspension system, the lighting control, the air bag, and the remotes are all independent functions. The ECU only gets notified when the active exhaust is turned on for fuel tuning.
    www.ClonedECU.com
    The home of the Original Clone and Clone2 ECU!
    More Plug n' Drive and less Plug n' Fail like the others!
    Remember, if it's not a Clone, it's just a copy!
    Get Chromed!
    Donate Now and receive a coupon code for the amount of your donation (up to $50.00 US) which you can apply at check out for a Clone2 ECU, Plug n’ Play Harness, or Clone2 Plug n’ Play Package!!
    1999 3000GT VR4
    Glacier Pearl White
    Yeah it's stock . . . trust me
    How To Contact Me:
    eMail: brett_farnam@yahoo.com
    US3S/3SGTO: 99 vr4
    3SI: bfarnam
  2. #72
    Canaan NH
    Quote Originally Posted by 99 vr4 View Post
    This is very interesting to me. My active exhaust doesnt work, but the switch does. Does the ECU look to the switch or to a limit switch on the motor? And is there much to gain by the ECU knowing the exhaust is free flowing?
  3. #73
    DC Metro Area
    And if it is on the switch is there any way we can take advantage of it for other purposes programatically?
  4. #74
    Oct 2010
    St Louis
    Yes and yes .. Greg had found some interesting things and he is working on it...
  5. #75
    Canaan NH
    Well fill me in, I am curious.
  6. #76
    Oct 2010
    St Louis
    That is best left for Greg
  7. #77
    OK, this active exhaust affecting the fuel map discussion needs to be discussed please. I have removed all but the motor, and wonder if this affect my performance via the switch still. If I remove the motor, or unplug, what affect if any does this have, and what is needed to disabled said affect?
    If this needs to go in the Chrome thread, let me know I will move it...
  8. The Following User Says Thank You to CoopKill For This Useful Post:
  9. #78
    Oct 2010
    St Louis
    This applies only to those using the stock ROM.
    If you no longer have an active exhaust system, then don't worry about it. Just don't play with the switch.
    If you still have a working active exhaust system, then after you are done tuning, check your tune with the active exhaust on. Don't tune with the active exhaust on.
    If you are using Chrome, check with Greg.
    There are still some unknowns with regards to this system....
  10. #79
    Oct 2010
    St Louis
    Ok... Time for a breather. I will be dropping the last of the outstanding orders in the mail Wednesday. Then I am on military orders for four days... So if you order, you mighty not get a response until Monday June 25...
    Thank You!
  11. #80
    You got mail.
