Code:
; OpenPort 2.0 internal logging file
; Chrome v2 ECU Parameters
; Must be named logcfg.txt and be placed in the root directory
; of the microSD card inserted in the OpenPort in order to work
; Use a 2GB maximum size microSD card, formatted FAT16 for
; optimal results
; This config logs using the MUT-II protocol over the K-line,
; and is customized to work only with a flashable 3000GT/Stealth
; ECU loaded with Chrome v2.1
; Posted by "mjannusch" on 3Si and 3SGTO for use by Chrome
; purchasers
;-----------MUT2 Settings------------
type=mut2
baud=15625
;baud=62500
; Default baudrate is 15625, but can be changed in the "Protocol
; MUT3 Baud" parameter in Chrome. Must also be changed in
; EvoScan to log with a laptop. Has no effect on logging rate
; with OpenPort logging, but 25% increase in sample rate with
; EvoScan
;---------Parameters to Log----------
; Sampgroups define how often a parameter is polled from
; the ECU. Higher numbered sampgroups will poll less often.
paramname=TPS
paramid=0x17
scalingrpn=x,0.39215686,*
sampgroup=1
paramname=RPM
paramid=0x21
scalingrpn=x,31.25,*
paramname=Battery
paramid=0x14
scalingrpn=x,0.07333,*
sampgroup=15
paramname=TimingAdv
paramid=0x06
scalingrpn=x,20,-
;These are not the params for a 98+ ECU)
;paramname=CoolantTemp
;paramid=0x07
;scalingrpn=x,1.593,*,38,+
;sampgroup=15
paramid=0x10
scalingrpn=x,1.8,*,40,-
sampgroup=15
paramname=2ByteAirFlow
paramid=0x00
databits=16
scalingrpn=x,0.09765625,*
;This is 2-byte Airflow, named as standard AirFlow
paramname=2B_ECULoad
paramid=0x02
databits=16
scalingrpn=x,0.3125,*
;This is 2-byte Load, named as standard ECULoad
paramname=MAPScaled
paramid=0xA1
scalingrpn=x,0.2745,*,20,-
; Scaled Pin 92 input, requires MAP sensor on pin 92
; and properly populated scaling table. See:
; http://www.3sgto.org/tuning-engine-e...tml#post211663
paramname=WBScaled
paramid=0xBF
scalingrpn=x,0.0627,*,7,+
; Scaled Pin 93 input, requires wideband on pin 93
paramname=KnockSum
paramid=0x26
scalingrpn=x
;sampgroup=1
paramname=Speed
paramid=0x2F
scalingrpn=x,1.2427424,*
;sampgroup=1
paramname=F_InjPulseWidth
paramid=0x2B
;scalingrpn=x,0.256,*
paramname=F_InjDutyCycle
scalingrpn=F_InjPulseWidth,RPM,*,1200,/
; Requires RPM and F_InjPulseWidth params to be logged above
paramname=Gear
scalingrpn=RPM,Speed,/
; Requires RPM and Speed params to be logged above
; Will give a rough estimation of the gear ratio.
; Not a number showing the actual gear.
paramname=WGDC
paramid=0x86
scalingrpn=x,2,/
paramname=WGDCCorr
paramid=0x8B
scalingrpn=x,0.5,*,64,-
paramname=Target_Load
paramid=0xB6
scalingrpn=x,0.625,*
; This value does not include the Boost Control Load Offset
;paramname=AFTarget
;paramid=0x32
;scalingrpn=1881.6,x,/
;paramname=KnockVoltage
;paramid=0x30
;scalingrpn=x,0.0195,*
;paramname=KnockBase
;paramid=0x6B
;scalingrpn=x
;paramname=Octane
;paramid=0x27
;scalingrpn=x,0.39215686,*
;sampgroup=15
;paramname=R_InjPulseWidth
;paramid=0x29
;paramname=R_InjDutyCycle
;scalingrpn=R_InjPulseWidth,RPM,*,1200,/
;Requires RPM and R_InjPulseWidth params to be logged above
;paramname=FP_O2Sensor
;paramid=0x3E
;scalingrpn=x,0.01952,*
; Front narrowband O2 sensor
;paramname=F_O2FeedbackTrim
;paramid=0x4F
;scalingrpn=x,0.1953125,*,25,-
;sampgroup=15
;paramname=F_FuelTrim_Low
;paramid=0x4C
;scalingrpn=x,0.19607843,*,25,-
;sampgroup=15
;paramname=F_FuelTrim_Mid
;paramid=0x4D
;sampgroup=15
;paramname=F_FuelTrim_High
;paramid=0x4E
;sampgroup=15
;paramname=RP_O2Sensor
;paramid=0x13
; Rear narrowband O2 sensor
;paramname=R_O2FeedbackTrim
;paramid=0x0F
;sampgroup=15
;paramname=R_FuelTrim_Low
;paramid=0x0C
;sampgroup=15
;paramname=R_FuelTrim_Mid
;paramid=0x0D
;sampgroup=15
;paramname=R_FuelTrim_High
;paramid=0x0E
;sampgroup=15
;paramname=VE
;paramid=0x31
;scalingrpn=x,100,*,128,/
;These are not correct for a 98+ ECU
;paramname=AirTemp
;paramid=0x3A
;scalingrpn=x,1.8,*,38,+
;sampgroup=15
; RETURNS INCORRECT VALUES, at least on my car
;paramname=AirTemp
;paramid=0x11
;scalingprn=x,1.8,*,40,-
;sampgroup=15
;paramname=Baro
;paramid=0x15
;scalingrpn=x,0.49,*
;sampgroup=15
;paramname=gmas
;paramid=0x00
;scalingrpn=x,0.0236,*
;paramname=AirMassGperCyl
;paramid=0x02
;databits=16
;scalingrpn=x,512,/
;paramname=CoilDwell
;paramid=0x2D
;scalingrpn=x,0.064,*
;paramname=AirflowRev
;paramid=0x1D
;scalingrpn=x,0.07843,*
;paramname=TargetIdleRPM
;paramid=0x24
;scalingrpn=x,7.8,*
;paramname=IdleError
;paramid=0x75
;scalingrpn=x,7.8125,*
;paramname=ISCSteps
;paramid=0x16
;scalingrpn=x
;paramname=MAPVolts
;paramid=0xA1
; Raw volts on ECU pin 92
;paramname=WBVolts
;paramid=0xBF
; Raw volts on ECU pin 93
;---------Logging Conditions---------
; Log whenever car is runing
conditionrpn=RPM,100,>
action=start
conditionrpn=RPM,0,==
action=stop
; Log only when TPS > 80%
;conditionrpn=TPS,80,>
;action=start
;conditionrpn=TPS,80,<
;action=stop
